letzter Beitrag 20.04.26 um 08:56 von  TuyetNga
MMOEXP-Elden Ring: Volcano Manor’s Single Perfume Bottle Location
TuyetNga Segler Segler Posts:7
20.04.26 um 08:56
    In Elden Ring, exploration is one of the most rewarding aspects of gameplay. Hidden items, rare crafting tools, and unique equipment are scattered throughout the Lands Between, encouraging players to Elden Ring Runes thoroughly explore every dungeon and legacy area. One such valuable but often overlooked item is a Perfume Bottle found inside Volcano Manor. While it may seem minor at first glance, Perfume Bottles play an important role in crafting powerful consumables that can significantly enhance combat performance.
    This guide explains exactly where to find the Perfume Bottle in Volcano Manor, how to reach it safely, and why it is worth collecting for both early and late-game builds.
    Understanding Perfume Bottles and Their Importance
    Perfume Bottles in Elden Ring are special crafting tools used to create Perfume items. These consumables provide buffs or offensive effects that can turn the tide of battle when used strategically. Depending on the recipe, Perfumes can boost attack power, enhance defense, or release damaging elemental effects against enemies.
    Because Perfume crafting is tied to exploration and item collection, players who actively seek out Perfume Bottles gain access to a wider range of tactical options. This makes them especially valuable for hybrid builds that rely on buffs or status effects.
    The Perfume Bottle found in Volcano Manor is part of this broader system and is one of several scattered across the game world. However, its location inside a dangerous legacy dungeon means it is often missed by players rushing through the main questline.
    Reaching Volcano Manor
    Before you can obtain the Perfume Bottle, you must first gain access to Volcano Manor. There are multiple ways to reach this area in Elden Ring, but the most common methods include:
    Joining Volcano Manor through NPC progression quests in Liurnia of the Lakes
    Being transported via the Abductor Virgin encounter beneath Raya Lucaria Academy
    Progressing through the Altus Plateau and traveling to Mt. Gelmir manually
    Once you arrive, you will enter a sprawling legacy dungeon filled with lava hazards, serpent enemies, and complex interior corridors. Volcano Manor is known for its branching paths and hidden rooms, making it easy to miss valuable loot if you do not explore carefully.
    Locating the Perfume Bottle in Volcano Manor
    The Perfume Bottle inside Volcano Manor is hidden within one of the manor's interior sections rather than the lava-covered exterior. As you progress through the main corridors of the manor, you will encounter multiple doors, illusionary walls, and enemy patrols. The item is typically located in a side room or optional exploration path rather than along the main progression route.
    To reach it, players should carefully explore the residential and lower interior sections of the manor. These areas often contain corpses with loot, hidden alcoves, and small rooms guarded by humanoid enemies or serpent-themed warriors.
    The Perfume Bottle is usually found on a corpse or resting on a small container inside one of these rooms. Because Volcano Manor is designed with layered exploration in mind, it is easy to pass by the correct room without noticing it, especially if you are following the assassination contract questline tied to the manor.
    A good strategy is to thoroughly clear each corridor before advancing. Look for breakable objects, open doorways on the sides of hallways, and any unusual dead ends, as these often indicate hidden loot locations.
    Enemies and Hazards to Watch Out For
    Volcano Manor is not a safe environment, and obtaining the Perfume Bottle requires dealing with several enemy types. These include:
    Serpent Soldiers who wield curved swords and shields
    Fire-based enemies that deal burn damage over time
    Hooded assassins who use quick dagger attacks
    Trap corridors that may include fire jets or ambush points
    Because of these threats, it is recommended to approach the manor with a balanced build that includes both ranged and melee capabilities. Shields with high fire resistance or armor sets that reduce flame damage are especially useful in this area.
    Additionally, be cautious when opening doors or entering new rooms, as ambushes are common. Many enemies in Volcano Manor are positioned to attack from blind spots, so maintaining awareness is essential.
    Best Route to Efficiently Find the Perfume Bottle
    To efficiently locate the Perfume Bottle in Volcano Manor, follow a methodical exploration route rather than rushing through the main questline.
    Start from the central hallway area after entering the manor and take note of any side doors that appear optional. Prioritize rooms that are not directly connected to the main progression path. These optional areas are where most hidden items are placed, including crafting tools like Perfume Bottles.
    As you move deeper into the manor, check every lower-level corridor and avoid skipping rooms that appear to lead to dead ends. In Elden Ring design philosophy, dead ends often reward exploration rather than punishing it.
    If you are following the Volcano Manor contract assassination questline, temporarily pause your mission objectives and explore thoroughly before continuing. Many players miss valuable items because they focus only on quest markers.
    Why the Volcano Manor Perfume Bottle Is Worth Collecting
    Even though it may seem like a minor item, the Perfume Bottle in Volcano Manor adds meaningful value to your overall progression. Perfume crafting allows you to create consumables that enhance both offensive and defensive capabilities, which can be especially useful in boss fights or PvP encounters.
    For example, some Perfume-based items can increase attack power temporarily, while others provide emergency survivability boosts. This flexibility makes Perfume tools an excellent addition to hybrid or support-focused builds.
    Additionally, collecting all Perfume Bottles contributes to completionist progression. Players aiming to fully explore Elden Ring's crafting system will need to gather multiple bottles across different regions, and Volcano Manor is a key early-to-mid game source.
    Tips for Exploring Volcano Manor Efficiently
    To make your exploration smoother, consider the following tips:
    Use a lantern or torch to improve visibility in dark interior areas
    Clear enemies methodically instead of rushing forward
    Listen for audio cues that may indicate hidden enemies or traps
    Check behind furniture, corners, and destructible objects for hidden loot
    Mark explored rooms on your mental map to avoid backtracking confusion
    By following a careful exploration approach, you significantly increase your chances of finding not only the Perfume Bottle but also other hidden items throughout the manor.
    Final Thoughts
    The Perfume Bottle in Volcano Manor may not be the most famous item in Elden Ring, but it represents the game's deeper design philosophy of rewarding exploration and curiosity. Hidden within a dangerous and complex legacy dungeon, it encourages players to slow down, explore thoroughly, and engage with the environment rather than rushing through it.
    For players who enjoy crafting, experimentation, and build customization, this item is a valuable addition that opens up new tactical possibilities. Whether you are preparing for boss fights, PvP encounters, or buy Elden Ring Items simply optimizing your character, the Perfume Bottle is worth the effort it takes to find.
