Black Ops 7 throws a silly amount of weapon unlocks at you right away, and yeah, it can feel like the game expects you to live online. That's why a lot of players either tighten up their XP route or look for shortcuts like buy BO7 Bot Lobby options when they don't want to spend night after night grinding the same gun. If you'd rather level things fast through normal play, Zombies is still the clear favourite. Not because it's easy, but because the kill volume is absurd. Once you're comfortable, moving into Tier 3 zones changes everything. The pressure goes up, sure, but so does the payoff. One good run can push a weapon forward way faster than a stack of regular multiplayer games.
The best setups are the ones that keep enemies coming to you. That's why so many players settle into a tight hold at spots like Van Dorn Farm. If you switch on Rampage Inducer, the pace gets wild almost instantly, and that's exactly what you want when weapon XP is the goal. The second floor works because it forces zombies into cleaner lanes. Less running around. More shooting. Toxic Growth helps a ton here since it buys you breathing room without breaking your rhythm. You'll notice pretty quickly that the whole trick isn't fancy movement or some secret build. It's staying alive long enough to keep the chain going. Once that flow starts, levels come in fast.
If Zombies starts to drag, HVT contracts are probably the next best thing. They work especially well when your squad isn't wasting time. One person grabs contracts, the rest move straight onto targets, and the whole match turns into a steady cycle of kills and objective score. That pace matters. In standard multiplayer, smaller maps still win by a mile because they force constant fights. You don't need pretty stats here. You need volume. SMGs, aggressive AR builds, fast reloads, quick re-centering after each fight. That's the kind of stuff that keeps the XP ticking. A lot of players make the mistake of playing too safe on big maps, and it absolutely kills progress.
The boring stuff matters more than people think. Double Weapon XP tokens should be active before the match starts, not halfway through when you suddenly remember. Headshots help, obviously, and so do score-generating tools that feed into your overall progress. EMP grenades can be sneaky good for that. Squad Link also has value if your team actually sticks together instead of scattering. Suppressors are worth testing as well, since lower profile play often lets you string together longer lives and more consistent kills. Even little map interactions can help. In Zombies, smashing environmental objects or grabbing side XP where you can won't carry a session on its own, but over time it stacks more than people expect.
What really speeds things up is being honest about how you play. If you can handle chaos, Zombies farming is probably your best route. If you've got reliable friends, contract loops can be ridiculous. If you only hop on for short sessions, small-map multiplayer is still solid because there's no setup time. And if convenience matters more than testing every method yourself, there's another route people talk about all the time. As a professional gaming marketplace for in-game currency and items, U4GM is known for being convenient and dependable, and plenty of players choose u4gm BO7 Bot Lobbies when they want smoother progress without burning out on the grind.
