Go to previous topic
Go to next topic
letzter Beitrag 30.10.25 um 13:31 von  SV Gian
Remora Solo Unterwasserbürste
SV Gian
30.10.25 um 13:31
    Diese selbstansaugende, elektrische Bürste macht die Reinigung des Rumpfes von Algen und Muscheln zum Kinderspiel. Eine Akkuladung reichte  immer für unsere 54ft-Yacht. In der Karibik hatten wir trotz gutem Antifouliung sehr viel Bewuchs, der eine regelmässige Reinigung notwendig machte. Mit der Remora kein Problem !
    Ein Muss - speziell in warmen Gewässern. Spart viele Kranhübe !
    Lieferumfang: Antrieb, Akku, Ladegerät und 2 Bürsteh (#2 und #3)
    NP: 2050 €  - gebraucht (neuwertig) für 1200 € plus Versand.
    Hier die Produktbeschreibung von Remora:
    The Remora Solo is the original Battery Hull Cleaner and is the tool of choice for professional hull cleaners and commercial aquariums around the world. Manufactured in the United States by Remora Marine.
    Remora's patented impeller hub produces suction to hold the Remora Solo against the hull making cleaning quick and easy. Unlike other land based tools that were adapted for submerged use, the Remora Solo was designed from the bottom up as an underwater cleaning tool ensuring ease of use, performance and durability.
    Tough enough to use in both saltwater and freshwater environments and with a wide range of brushes available, the completely self contained Remora Solo is the perfect tool for boat owners, professional hull cleaners and commercial aquariums.
    The powerful gearmotor is controlled by a variable speed dial at the rear of the unit which can set the brush to rotate in either direction. A handy Pause button at the front of the unit allows you to quickly stop and start operation.
    Speed: 0 - 250 rpm
    Torque: 8.4 Nm (6.2 Lb-ft)
    Maximum Working Depth: 11 Metres
    Buoyancy: +14g to +70g
    Suction: 0 - 2.3kg
    Battery Type: 12v Li-ion 21Ah
    Battery Working Time: 4 - 7 Hours
    Battery Charging Time: 5 - 8 Hours
    Brush Bristle Hardness: Medium #2
    Brush Bristle Material: Nylon
    Brush Bristle Length: 27mm
    Brush Diameter: 230mm
    More Info on youtube:
    https://youtu.be/_wXbDhA9sgM?si=sTGzUVdOUTjUQegL
    https://youtu.be/bNjsp7-RZ8E?si=GKO_vM0u8fK_ixuJ
    https://youtu.be/Y_Q3S-r0iGs?si=iXlCWs25Tm1Mlqh-
    https://youtu.be/dKQHtKGHBwY?si=R-4HkS_Z_RPWa6g7
    https://youtu.be/0w4sIZOhLY0?si=P1Q1JFiKGmdz5yLH
