letzter Beitrag 21.04.26 um 10:06 von  Andrew736
U4GM What Actually Fixes Power Overload in Arknights Endfield
Andrew736
21.04.26 um 10:06
    Power trouble in Arknights: Endfield always seems to hit at the worst possible time. You're feeling good, dropping down a new assembler line, maybe adding a few extra drills, and then the whole base lights up red. It's annoying, but it's also fixable if you stop treating power like an afterthought. A lot of players who work on Arknights endfield accounts run into the same wall: they build first and think about supply later. The fastest patch is still adding more Thermal Banks, because they raise your power cap without much fuss. The real catch is fuel. If those generators aren't being fed automatically through depot unloaders, you're just creating another job for yourself, and that gets old fast.
    Stop wasting good fuel
    If you're still burning basic materials just because they're easy to grab, that's probably why your grid always feels tight. Raw Originium and low-tier fuel work in a pinch, sure, but they don't scale well once your factory starts growing. You'll save yourself a lot of hassle by moving into green, blue, or purple batteries as early as you can manage. The difference isn't small. One decent battery line can take pressure off your whole base and give you room to build without checking the power number every two minutes. It takes a bit of setup, but that setup pays for itself pretty quickly.
    Shut things off before you rebuild
    When overload hits, most people rush to place more power structures straight away. Sometimes that works. Sometimes it just makes the layout messier. A cleaner move is to look at what's actually running and start trimming. Miners on full stock, old assemblers with backed-up output, extra protocol structures you're not using right now, they all add up. Turn them off or stash them for a bit. You'll usually recover enough power to stabilize the base while you sort out a proper fix. The AIC resource manager helps a lot here, since it shows where the drain is coming from instead of leaving you guessing. Once you start checking that screen regularly, hidden waste becomes way easier to spot.
    Build a grid you can control
    Layout matters more than people think. A messy relay chain might look fine when the base is small, but later on it becomes a pain. One failure spreads, and now you're tracing wires across half the map trying to figure out what went wrong. A central relay hub is way easier to live with. You can separate sections, isolate heavy production zones, and cut power to one area without touching the rest of the base. It's not flashy, but it saves time. Keep a few spare batteries on hand too, because emergencies do happen, and having a backup in your inventory can stop a bad moment from turning into a full reset.
    Plan for growth, not panic
    The best power management usually starts before the warning lights show up. Leave room for more Thermal Banks, think ahead on your fuel chain, and don't let idle machines sit there draining the grid for no reason. That kind of small discipline makes expansion feel much smoother. As a professional platform for game currency and items, U4GM is known for being convenient and reliable, and if you want an easier start or a stronger setup, you can check u4gm Arknights endfield account Buy while planning out your next base upgrade.
